I burn my movies just fine with Nero 6.1, but why cant i play them on my DVD player. If i place the DVD into my dvd-rw it will play throught WMP. When i go to put in my 2 dvd players I get the message "cannot play disk" or "There is no disk".
I thought nero would allow the disc to be played in any player. Is there anything i have to do to the disk for it to work. The files I burn are AVI files, I see a lot of people talking about TMPGEnc, would this help me in this situation. If so can you tell me how and what i need to do. My dvd player is a RCA model RC5230z (it also has divx on the front), and the other is a sony DAV s300.
any help
Nice.............
I don't think any DVD player is going to play an AVI file. The files have to be converted to DVD compliant mpeg2. If you're new to all this I suggest you invest in neoDVD Plus then work up to the more complicated programs. You can check out NeoDVD here. http://www.mediostream.com/neodvd/index.html
Lite-On LVD2001 supports MPEG-4 Divx and xVID: https://www.videohelp.com/dvdplayers.php?DVDnameid=2509&Search=Search&#commentsOriginally Posted by Bob W
as well as Kiss DP450: https://www.videohelp.com/dvdplayers.php?DVDnameid=1502&Search=Search&#comments
and Kiss DP500: https://www.videohelp.com/dvdplayers.php?DVDnameid=1983&Search=Search&#comments
@nice24,
BUT i highly doubt your players support Divx.... this means you have to do what Bob W sez and convert your MPEG-4 Divx to DVD compliant MPEG-2.
guide: http://www.doom9.org/index.html?/mpg/avi2dvdr.htm -
so once I convert my movies to mpeg-2 they should work.
I used TMPEGnc last night. Converted my avi. to mpeg-2 once i burnt it and tried to play on my dvd. It still says disk is not compatible why do you think this is.
Nice -
did you author your DVD??? you can't simply burn the .mpg file as a DATA DVD....you need to author the .mpg file to a DVD VIDEO.Originally Posted by nice24
authoring guides: https://www.videohelp.com/forum/userguides/139093.php
https://www.videohelp.com/forum/userguides/78179.php
https://www.videohelp.com/spruceup.htm
https://www.videohelp.com/forum/userguides/120013.php -
Oh so I have to add menus and chapters for it to really work. Just having the movie and then converting it....isnt enough.
OK..so if thats right I'm doing ok cause, I have DVDLAB it works nice still trying to work some things out.... there. But I see what it can do, I got held up cause I have a 20gb HD and alot of large movie file so when I tried to compile my fiirst movie HD space got lower from all the work. so, I'm deleteing some partials and just gonna go with my whole movies.
so I am I on the right track
ONe....
Rca drc6309 protable dvd player
By riz in forum Portable VideoReplies: 1Last Post: 19th Sep 2011, 19:38 -
RCA DRC247N constantly pausing while playing commercial DVD's
By Robnorth in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Dec 2007, 23:00 -
RCA DVD player problem with DivX
By 4194 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 28th Aug 2007, 13:12 -
unlock dvd player RCA 5500P
By galokar in forum DVD & Blu-ray PlayersReplies: 0Last Post: 27th Jul 2007, 16:27 -
hack code for DVD player RCA
By chrissi34 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th May 2007, 12:20
