Kazaam Gold Studio 2.0 package includes software that allows you to
copy a DVD, to a single CD.
Is there any freeware that I can get hold of to do this in a very easy fashion.
I do not mind using 2 CDR s of 700 MB to contain 4.7 Gb ..
you do realize that you are not going to get 4.7Gb of data into 1,400 Mb, right?I do not mind using 2 CDR s of 700 MB to contain 4.7 Gb ..
do you have a link for this software? many of the software packages out there for this purpose are nothing more than the same shareware or freeware programs you get here, with a graphic interface which takes away most of the control and hides the fact that it's a bunch of freeware doing the work...
here's a hint... if they don't offer a trial download, it's probably a collection of freeware programs...- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
this requires a LOT (and i mean a LOT) of compression...your quality will be lousyOriginally Posted by faithfoo
however, if you insist, check out www.kvcd.net
oh...so many errors...Originally Posted by faithfoo
1) technically, you're gonna be making some sort of (S)VCD...so this allows you to fit 800 MB on each 80-min CD-R....so, if you're gonna use 2 of them..that would add up to be 1,600 MB.
2) DVD-R/+R's actual size is 4.38 GB.
3) how the hell did you think 2 CD-Rs that can hold 1,600 MB be able to hold 4.38 GB???? you need to burn to DVD-R/+R (and yes, go buy a DVD burner) if you wanna fit 4.38 GB. CD-Rs won't work.
otherwise, if you insist on using CD-Rs (NOT DVD-R/+R), then you need to create (S)VCDs...which have much smaller filesizes than DVDs and also lower quality. -
Sorry folks ,
I actually mean compression to VCD
I am just wandering what Kazzam gold is offering to put 1 DVD To 1 CD .
1) Based on an acceptable compressed quality how many CDRs will need to contain a compressed DVD
2) WHAT;S THE SIMPLEST WAY TO DO THIS ...THE COMPRESSION OF dvd INTO vcD ( i already have all the vob files in THE hdd) -
standard, compliant VCD allows 80 min of video to fit on 80-min CD-R.
https://www.videohelp.com/sefy/?id=DVDx.html
https://www.videohelp.com/sefy/?id=direct6.html
https://www.videohelp.com/sefy/?id=intro.html
READ THE GUIDES CAREFULLY
accounting software for Mac bookkeeping software for Mac
By Noahtuck in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2017, 13:43 -
Why does this movie playing software not work? (Bluray software)
By oz_surfer in forum Software PlayingReplies: 5Last Post: 31st May 2010, 03:18 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 19:26 -
Developing software that uses opensource or GLP software
By wiseant in forum ProgrammingReplies: 4Last Post: 10th Sep 2009, 08:07 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 21:45
