  1. I get crazy error messages:
    1. Access Violation in capture routine.
    Virtualdub has intercepted a crash condition in one of its routines.
    or
    2. PANIC: VirtualDub cannot connect to any capture drivers!
    I can see a black screen in the VDUB windows as this message comes up.
    But, I have WinXP and Mainconcept DV Codec installed and picked as compression. I have a sony firewire DV camera.
    why does this not let me capture???
  2. did you try "windows moviemaker" ?
    it comes with windows xp (start=> programs=>accessories).
    as far as i can remember Virtualdub doesnt support importing DV from a camera, but it can handle the dv AFTER you import it to the computer.
    can someone confirm that ?
    but i think moviemaker will let you import from your camera into the computer and edit the avi file.
    and i heard its a good idea to upgrade to moviemaker 2.
    after you do that you can encode it to whatever format you want
    using an encoder.
    HELL AINT A BAD PLACE TO BE
    Mar 2002
    Have you looked and posted in the Mainconcept forum and/or e-mailed or called their support staff ?
    Dec 2001
    using an encoder.
    This is true. I used DVIO or MS MovieMaker to transfer from minidv to the hard drive, then I can use Virtualdub. BTW for some reason when I upgraded to MS MovieMaker 2.0 I was unable to use the transfered avi file. I'm sure it had to do with the type 1/type 2 issue, but I couldn't capture in the virtualdub readable format even after I reloaded the mainconcept codec.
  5. This is true. I used DVIO or MS MovieMaker to transfer from minidv to the hard drive, then I can use Virtualdub. BTW for some reason when I upgraded to MS MovieMaker 2.0 I was unable to use the transfered avi file. I'm sure it had to do with the type 1/type 2 issue, but I couldn't capture in the virtualdub readable format even after I reloaded the mainconcept codec
    i didnt know it can cause problems, i just heard that moviemaker 2
    has improvments over the original.
    might be a good idea to stay with the old version after all.
    good point chaseru
