I am trying out the Morgan Multimedia MJPEG codec. Their
web page suggests that you get the best performance (highest
fps) if you use YUV2. My system doesn't have that as a
choice, however. How would I get it? My capture card
is an ATI TV Wonder.
Thanks,
Mike
Install Huffyuv. http://www.math.berkeley.edu/%7Ebenrg/huffyuv.html
Hi Truman,
Thanks for the reply. Do you mean to install Huffyuv to use it instead of MJPEG, or to install
it to get YUV2? I already have Huffyuy installed, and I had problems getting it to work on
my system, but it is an old version, so I will try to load the newest version and try again.
Mike -
Try using YUV9, I started using DIVX 4.01 and it would not reconize YUV2 or YUV12, but it did work when I set my capture card to YUV9.
To set these AVI codecs you need to set them up from your Capture card software 1st, I did mine from VituralDub. -
choice, however. How would I get it?...
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Have a look at c:\windows\system.ini, at the [drivers32] section watch out for the line
VIDC.YUY2=???????
Define the codec, I use VIDC.YUY2=huffyuv.dll
Can my Laptop support TV Out?
By soneman in forum Software PlayingReplies: 12Last Post: 15th May 2008, 12:17 -
AVCHD support....please!
By motoxer913 in forum ffmpegX general discussionReplies: 2Last Post: 6th May 2008, 09:44 -
EyeTV Support?
By fromeout11 in forum ffmpegX general discussionReplies: 1Last Post: 7th Oct 2007, 10:37 -
Gamebridge support
By alsuse in forum LinuxReplies: 0Last Post: 17th Sep 2007, 22:12 -
SDK Support
By jain30 in forum Authoring (DVD)Replies: 3Last Post: 22nd Jun 2007, 08:50
