i use easy cd creator both 4 and 5 platinum to burn my vcd's
i use ulead media studio to convert it to vcd format before i try to burn. My problem is if i make a small vcd just a couple of video clips with a simple menu structure and all they will play fine. But when i try to burn a large file like half of a screener it shows the pictue but has no sound.
what can i do to fix this and why is it happening? please i wasted to many cdrs and i want to watch my movies on vcd
Results 1 to 1 of 1
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 21:03 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
What's the best-easily working program to rip sound from vcd ?
By billyww in forum AudioReplies: 1Last Post: 20th Jan 2009, 06:30 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
