Here's my first creation with using the program, which I found to be very useful. This logo will go on my website soon. Tell me what you think.
Results 1 to 26 of 26
It's not bad, but could use a little more detail. The plain white letters could use some color, maybe graidiant.
Personally I think Photoshop is the best image editor.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
You can't really see the lights very well so i guess I need to do something about that.
Yeah I saw this. I used a luminescence option in PSP8 to recreate the lighting, and it turned out pretty good except for that.Originally Posted by funkguy4
Got some rough edges there... on the lights, i can understand, have that prob myself and it's a bitch to fix (usually needs a lot of by-hand pixel punching). But how come the letters are? Did you cut & paste them from elsewhere rather than using the text tool?
Hrm..
As for the light gradients, I can't offer any help, apart from saying that it just looks wierd
don't think it's a compression problem, they usually look distinct from how that is.
-= She sez there's ants in the carpet, dirty little monsters! =-
Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more! -
The text tool made the words extremely pixelatedOriginally Posted by EddyH
So I used MS Paint and used PSP to clean up the rough egdes. (They were worse)
Blurring made it worst so like I said I used the "clean the edges" tool.Originally Posted by funkguy4
The light pools almost look as though they're rendered in 16 bit colour or something. odd. Reminds me of the effect you see on the backdrops in Futurama.
MS Paint for cleaning up the pic and text, when you've got Paintshop? Why?!
Why? Because I've worked with MSPaint for the last six years and I got PSP8 the other day.Originally Posted by EddyH
um... ok then
i still advise you ditch it and crash-course into the new program. paint has little to offer that psp doesnt-= She sez there's ants in the carpet, dirty little monsters! =-
Well, Familiarity is a huge advantage. Paint is not too powerful, but if it does what you want it to do, and you are already familiar with it. There is not much reason to rush into learning something different. Just let it come naturally. I did the same thing when I first bought PSP7. I used MSPaint for awhile, and occationally still do, as I learned PSP. Working with individual pixels is a little more straight-forward in MSpaint.
Another thing is the Hex editor I use is over 8 years old! Obviously it does not have a lot of advanced functions. It works, I like it, that is all that matters."A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
Were the whites lines in the light stream intentional?
They look superb.
To me it looks like a couple of studio lights in front of a white painted brick wall.
Was this intentional?
How did you create the lighting effect?
So did you cut and paste in the camera/light units?
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
No, probably not, but can you see what I mean?Originally Posted by funkguy4
How it looks like a white painted brick wall and the light is just illuninating it?
Looks very cool, to me anyway!
W.tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
You see it mainly near the top of the light, near the bulbs. It does att this cool kinda look to it, but I doubt it was intentional.Originally Posted by Will Hay
Yep, and that's the clever part.Originally Posted by tgpo
The light would be the brightests nearer the bulb, therefore more of the 'back wall' would be illuninated.
The further down the light beam the less of the back wall you would see.
Excellent, intentional or otherwise
Much appreciatedOriginally Posted by Will Hay
New and sortra improved, based on your suggestions:
that looks much better, but i think the light pool from the lamp on the right should be about 10-15 degrees further clockwise to match up right.
Well the text is still looking a little... funny... (certainly not horrible) but otherwise that's sweet in comparison. Well done 8) 8)
= There's the question of familiarity. Working with individual pixels in Paint is a lot easier =
Um? You *do* know PSP has a zoom tool and a pixel-width pen tool right? Just like paint
Though I can see where you'd be coming from if you meant 3.1 Paint, where you get a good handy real-size preview of the part you're working on in a corner of the zoom view. THAT was good.
As for familiarity, they're not that different to work on really, just PSP has more tools and more flexibility (which i admit may be a little hard to get used to). If you just play with it for an hour or so it all starts to come very easily though. Not too difficult to figure out how to set brush size for example, or what hardness, opacity, and density mean. Better to quickly familiarise yourself with a good tool than to not use it at all in favour of a frankly primitive familiar tool.
Pretty much the two things I can think of paint doing 'better' than PSP:
1. Quick colour selection. Providing you only want to choose from 24 different colours, and the default ones are all you want to use, or you've already set the ones you need. (does it have an eye dropper tool yet? or is it still trial-and-error / spray 'n' pray?). PSP is a bit harder to quickly choose primaries from, but is far ahead in the eyedropping / choosing whatever colour you want with a couple seconds of work stakes.
2. Quick ability to make ellipses and box shapes. Flat colour, non-anti-aliased ones.
okay, i'm getting deep into a discussion about psp vs paint. this cant be good
Yes, I do. But lets not hijack the thread. My point is not that Paint is better than PSP, I don't think it is. My point was if a simple program does what you need it to do, there is nothing wrong with using that over a more complex program. Especially if you have experience with the simple one.Originally Posted by EddyH
And to answer your question, Paint does have an eyedropper
It took me a few days to find out how to unselect an area
. I kept clicking "undo", instead of the "select nothing" in one of the menu areas. Yes, I will have to get used to the complexity, but MS Paint opens quicker
What paint program do you use for your computer?
By johns0 in forum PollsReplies: 26Last Post: 25th Nov 2011, 05:02 -
Paint Shop Pro - "Sin City" effect?
By stantheman1976 in forum ComputerReplies: 5Last Post: 30th Apr 2009, 16:56 -
FREE Download of Corel Paint Shop Pro X Software
By MJA in forum Off topicReplies: 0Last Post: 13th Apr 2009, 20:55 -
Paint.NET is a very good free image editor!
By racer-x in forum ComputerReplies: 1Last Post: 19th Feb 2008, 13:51 -
PROBLEM: Animation Shop Won't Export To Paint Shop Pro 8
By Aaron1927 in forum EditingReplies: 1Last Post: 10th Jul 2007, 10:44
