I've just downloaded an XvidD and the sound appears to be out of sync by about 2-3 seconds. As I'm new to this, have I done something wrong or do I need to do some additional tweeking to the avi?
Thanks in advance
Massdark
It starts off at about 8 seconds out of sync and after that it's hard to tell -- the entire duration of the Xvid is 1hr 29mins.
The audio is about eight seconds behind the visuals -- not sure if it gets progrssively worse as I have no reference point.
Thanks for the help
Massdark
Does it get progressively off sync, or is it off from the start? If progressive, is it too fast or too slow? -
What player are you using? If you are using Windows Media Player try switching to a different player.
I use Media Player and I also have sound that is off. What is the issue with Media Player? It is usually very solid for me.
What player should I use? Will the file work in the DVD player even though the sound is off in Media pLayer?
LS
SYNC PROBLEM: X264 AC3/DTS MKV --->>> Xvid with VBR mp3?
By Randm in forum Video ConversionReplies: 6Last Post: 30th Jul 2013, 17:57 -
Xvid Sync Problem
By Peru in forum AudioReplies: 4Last Post: 21st Feb 2011, 13:15 -
XviD avi out of sync
By Silenceville in forum Video ConversionReplies: 17Last Post: 17th Feb 2009, 10:12 -
How do I sync xvid and audio?
By BiggerJim in forum AudioReplies: 0Last Post: 22nd Feb 2008, 19:35 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22
