Hey Guys,
Recently I came across a method to play PAL DVDs on an NTSC only system by simply changing the video information from PAL to NTSC for the main movie and menu in the VIDEO_TS.IFO and VTS IFO files using IfoEdit. It turned out to work, menu is displayed perfectly and runs smoothly, although when I go to play the movie it is displayed correctly but slows down for a split second in about 1-2 second intervals so that you end up getting a rather choppy type effect, not very noticiable at first, but becomes very apparent when a camera pans across a scene or a lot of motion occurs. I was wondering if there was anything I could do (other then re-encode the entire thing) that would potentially fix this problem,
Input would be appreciated,
Thanks![]()
Good question. Things like this quite often tend not to work properly. I think the best bet would be to re-encode
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 12:34
