I capture from a (cable) tv source using Huffy @ 480x480. The output turns out great or atleast good. Then I tried encoding to SVCD Template. After the encode, it turns out great as the source... well, kinda. There are 'random' incidents of noise block occuring in fast scenes. I encoded with TMPGEnc using 'High Quality' and @ CBR 2200kbit ... Here's a sample of what it looks like.
EDIT: Picture unavailable due to no available host. =|
It can't be the 'bitrate' cause I encoded at a high bitrate. On the original AVI video, that same scene looks fine - no noisy blocks. This 'noise block' only happens occassionally, mainly at fast scenes. Any ideas?
<font size=-1>[ This Message was edited by: Jeomite on 2001-09-30 21:54:04 ]</font>
OK, here's another followup to this 'problem' =(
This time is from a DVD rip (!!!). I just encoded Transformers DVD -> SVCD @ 2300kbit with CCE. I get 'random' noisy blocks, mainly at fast-action scenes. Any ideas?
<font size=-1>[ This Message was edited by: Jeomite on 2001-10-03 22:45:27 ]</font>
remove noise and block.
By mathmax in forum RestorationReplies: 124Last Post: 21st Mar 2014, 15:51 -
Weird, very weird thing demuxing a DVD
By jairovital in forum EditingReplies: 17Last Post: 22nd Oct 2010, 18:31 -
Multi-colored block noise bug in Adobe Premiere - DV video
By tat2jr1 in forum EditingReplies: 0Last Post: 23rd Jan 2010, 02:20 -
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 00:57 -
weird sound after noise removal in audacity
By happydog500 in forum AudioReplies: 25Last Post: 3rd Oct 2008, 08:24
