I just encoded a backup of a dvd to my hard drive.
The result were 6 different VOB files along with 6 accompanying auxiliary files.
My Pinnacle Studio 8 does not recognize these files
I'm looking for a a good DVD ripping program I can download to burn the backup DVD. I would prefer feeware, or any other suggestions.
Thanks for your help!
Jim
Results 1 to 9 of 9
TMPGEnc DVD Author has a burning engine in it. If you can create and ISO then DVD Decrypter can burn that to do what you want as well.
Thanks for your help. The guides are good, but the problem is that DVD Decryptor apparently only works on ISO files that it created
The VOB files created by DVD Shrink will not be recognized.
How can you go frm a VOB to an ISO file format???
I'm familiar with .avi and .mpg but war are ISO and VOB files? -
VOB Instant DVD: https://www.videohelp.com/instantdvd.htm
another guide: http://www.doom9.org/index.html?/mpg/dvdshrink2-main.htm
RecordNow Max: https://www.videohelp.com/tools?tool=20#comment
a semi-guide here (you need to scroll down to the part of the guide that explains RecordNow Max): https://www.videohelp.com/forum/userguides/146795.php
CopyToDVD: https://www.videohelp.com/tools?tool=118#comments
a semi-guide here (you need to scroll down to the part of the guide that explains CopyToDVD): https://www.videohelp.com/forum/userguides/141024.php
ImgTool & DVDdecryptor (FREE, btw): https://www.videohelp.com/forum/userguides/152875.php
Nero: https://www.videohelp.com/forum/viewtopic.php?t=127624 -
I have tried to use IMGTOOL to no avail. It just keeps popping up warning boxes about vts folders needed below or somthing like that. Any imgtool experts out there? I like to use ddvddecrypter to burn with because it isn't choosy about the type of media in my sony dru500a.
Roy -
How did you back up your source DVD? Are all of the files in the VIDEO_TS folder?
My first thought would be that you didn't copy VTS sectors when you backed up the DVD. OR you didn't put the VIDEO_TS folder on the root dir (which IMGTOOLS wants/needs). OR you didn't make the folder all caps (it does matter).
How to author & burn a DVD from VOB trailers/files
By Baldrick in forum User guidesReplies: 62Last Post: 30th Sep 2011, 06:39 -
Burn - VOB without IFO & BUP files?
By Miss Sherlock in forum Authoring (DVD)Replies: 25Last Post: 24th Aug 2009, 01:20 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 20:10 -
Burn VOB files with included Subtitles
By psyget in forum ffmpegX general discussionReplies: 1Last Post: 24th Jun 2008, 18:49 -
Want to burn 2 .VOB files to one DVD??
By herbster in forum Authoring (DVD)Replies: 4Last Post: 7th Aug 2007, 23:58
