They're not in the Media list and DVDInfo hates me. They're orange w/ a black line drawingof mountains and valleys, and on the left side it says:
1X
DVD-R
______
4.7GB
With lines for labelling under that. The right side has the DVD-R logo.
Thanks,
-David
The only disc Ritek makes in common issue currently I think are G03 (1x) and G04 (4x). If the bottom is purple you have a G03, if its kinda an off color you might actually have a G01 which is the very first disc I ever found for under $3 each that worked, WAY back, (Way means a year or so with DVD burners of course) but I don't think anyone really uses those disc any longer.
My 4X G04s from allmediaoutlet.com fit that description. Try DVDDecrypter to determine the manufacturer of the disk.
Ripping To HDD For Media Extender/Set Top Box Playback
By Satchmo in forum DVD RippingReplies: 8Last Post: 18th Feb 2010, 18:25 -
3 Digit manufacturer's code for Toshiba SD-V395KC
By Snakebyte1 in forum Newbie / General discussionsReplies: 1Last Post: 7th Apr 2009, 11:15 -
Same media code, wildly different reviews
By richapple in forum MediaReplies: 5Last Post: 1st Feb 2008, 01:25 -
portable media center in addition to set-top player?
By celchlepp in forum Newbie / General discussionsReplies: 2Last Post: 26th Jan 2008, 13:30 -
which online media store(s) shows Manufacturer ID ?
By archaeo in forum MediaReplies: 6Last Post: 5th Jan 2008, 20:35
