Can someone please help me. I can't even start the program. It keeps telling me that be sweet doesn't exsist. But that's not true. I have be sweet
Sounds a bit like you havent got it in the right place or got the correct version..or maybe even not exctracted the zip file...
Path should beProgram Files\Badgersoft\SVCD2DVDMPG+\besweet
Not too sure on what version is needed, check the main site but i'm using BeSweet v1.5b18..
Btw, when you post a problem Help Me as a title isnt very helpfull....
Try to put what you problem is...
Something like
BeSweet problem give others a chance to help as a lot wont even bother to read posts with titles like yours...[/list]Not bothered by small problems...
Spend a night alone with a mosquito -
iooi is correct: see sticky post SVCD2DVDMPG+ Installation & Common Issues
