I was able to get AVI_IO working when I switched the path for my output file to my slave drive which had much faster read/write speeds. So, it was working great. Then, when I got up this morning to get back to capturing, when I set the path for the output file (which you have to do everytime you open the software along with resetting all of the other settings...quite annoying), it gave me the following error message:
You specified a filesize bigger than the space available on this drive
This is ludicrous as I have 1.911 gig left on my HD, and I never even specified a filesize. I used the same settings that I had used yesterday when it was working.
Any advice?
Results 1 to 1 of 1
how mpegts works
By alntke in forum Newbie / General discussionsReplies: 2Last Post: 15th Mar 2011, 11:36 -
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 18:07 -
Device Capture - USB, Works With PAL / NTSC, Works with VirtualDub/VCR
By Drazick in forum Capturing and VCRReplies: 0Last Post: 7th Aug 2010, 18:27 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 05:58 -
.srt sometimes works.. sometimes doesn't
By jaxwire2003 in forum SubtitleReplies: 3Last Post: 19th Feb 2008, 08:03
