what is the best codec to use to compress a very very short video clip down, its only 6.4mb uncompressed. i am not that bothered about the qaulity, i just want a codec that can reduce the video in size, a lot.
thanks
I guess xVid or DivX would be best, but I expect you had thought of that
i have tried DivX, with good results, i think i got it down to 20kb but the quality goes bad, divx can take it to 100kb with good quality.
i never thought of xvid though, i'll give it a try.
Which codec
By Tafflad in forum Video ConversionReplies: 2Last Post: 25th Jul 2011, 20:58 -
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 15:10 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 20:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 10:41 -
Which codec is the best?
By tuanvn.2007 in forum DVD RippingReplies: 3Last Post: 27th Sep 2008, 07:40
