  1. I've been trying out DVD-lab and it meets my needs quite nicely except for one area. I find it lacking in tools for working with the graphical aspects of the menu objects. I need a program that will let me select multiple objects and make them the same width or height, space them out evenly, line them up, etc.
  2. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    you can do this with DVD Lab, although I don't think (at least in version 1.1) that you can select multiples at one time.
    but if you right-click on an object, select "Change Size" from the drop-down menu.
    that will allow you to change the x and y placement, and the height and width of the object.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
