Just installed it today.
Then i installed the drivers (ALL_DRV_878_Teletext_30625).
Seemed to go smoothly.I restarted.
I tried to capture from VHS with VirtualdubMOD,but a)it was without color (although i set it to PAL-B) , b)the bigger formats were "unsupported"
Do i need the PVR programm to capture at any resolution ? I downloaded it twice and both times ,i got a corrupted file.
On the site there are 2 sets of drivers.The ones i mentioned above, and these --> ALL_TVDV_30130 . Should i try these ?
thanks for any help.
VDub and all its derivatives have problem with high resolution.
You have 3 options:
1. using WinFast PVR
2. download VirtualVCR_MOD from
http://wave.prohosting.com/avarakin/Video/
It has a fix for SAP sound problem.
3. use btwincap drivers with vdub, but many people have problems with these drivers -
Hi,
thanks for the reply,i'm checking VirtualVCR now.
I could not download the newest Winfast PVR !
I downloaded it 3 times.2 from the US server and 1 from the taiwan server.
All three were corrupted ! (used flashget,which never had problems).
So i installed the one from the CD which is a January 2003 version.
It's cool, but it doesnt let ME choose whatever resolution i want ! When for example i set it to capture Uncompressed 720x576 , it switches back to 320x240 !
Also , in the capture options, i see 3 buttons near the "capture profile option" : "add" "modufy" "delete" .
However ,the most important of the 3 , the "modify" button , is never highlighted and cannot be selected !
I think i\ve heard i could capture at any setting i want with this card
Is this something that got fixed with the new version of PVR (the one i cant download) ?
thanks for any help from anyone
Leadtek Winfast TV2000XP Expert problem with sound
By roc383 in forum Capturing and VCRReplies: 22Last Post: 1st Dec 2010, 12:32 -
Does the SpursEngine devices, IE Leadtek's WinFast PxVC1100 work good?
By TBoneit in forum Video ConversionReplies: 3Last Post: 15th Aug 2009, 17:50 -
Leadtek Winfast pvr2000 (retail)
By fulgur in forum Capturing and VCRReplies: 7Last Post: 4th Nov 2007, 10:05 -
Help: No sound at all with a Winfast TV2000 XP Deluxe
By Deathwish238 in forum Newbie / General discussionsReplies: 3Last Post: 18th Aug 2007, 13:01 -
Leadtek Winfast TV2000 xp deluxe help
By Nuwanda in forum Capturing and VCRReplies: 0Last Post: 6th Jun 2007, 14:22
