I have VCD's that I'd like to author to DVD, both PAL and NTSC.
For PAL VCD Source:
You can add it to the asset bin, but when you drag a PAL VCD source from the asset bin to a movie frame, DVD-lab crashes.
For NTSC VCD Source:
When you add them to the asset bin, DVD-Lab complains that there is a problem with the aspect ratio, but this warning can be ignored. As a side note, I've taken a look at the sequence headers of MPEG1 using DVD-Patcher, and I notice that more often than not the specified bitrate is totally wrong and the aspect ratio is not specified. DVD-Lab should take this kind of stuff into account, and also let you *set* the aspect ratio for any given movie.
Now, when you drag the NTSC source to a movie frame, the preview is just a solid green screen. This makes it impossible to add chapters.
Conclusion:
As far as I can tell, DVD-Lab is completely useless for authoring VCD sources to DVD, either PAL or NTSC.
Results 1 to 1 of 1
DVD writer doesn't work
By kamyogi in forum DVD & Blu-ray WritersReplies: 6Last Post: 20th Apr 2011, 11:43 -
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 19:07 -
Please help! New DVD player doesn't work :(
By confuzedinTN in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Sep 2010, 14:44 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 06:58 -
Video Type Doesn't Match prob when compiling DVD Lab Pro project
By ulrichburke in forum Authoring (DVD)Replies: 6Last Post: 11th Dec 2007, 14:31
