I just purchased an Alba 108 its not an xi, but at the moment I can't get it to play vcd's, I know it seems like evrybody is getting tired of hearing the same thing. But anyway I've tried the hacks in the hack section but I still can't get it too work. When I try the 2182 hack what happens is that the secrect menu stays up and the display panel says open even though the disc has been inserted. Also if I try the other one where you press 1, all it does is say - Incorrect Disc Format - then it spits out the disk. Can anyone help. Thanks in advance!!
I had an Alba 45xi replaced with the Alba 108, because i thought it plays vcds!
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
Problems with Alba 108 DVD player
By Normie in forum DVD RippingReplies: 1Last Post: 13th May 2010, 12:44 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
Advice needed for Recording using Alba DVD recorder
By rhicel in forum MediaReplies: 2Last Post: 13th Mar 2008, 11:26 -
Alba dvd382stb
By djmagnifique in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Jun 2007, 18:10
