Results 1 to 9 of 9
  1. I hope someone can help. I am using TMPG Plus 2.5. I have tried several avi types but after I complete the encoding process their is no sound. I am taking both the audio and video from the avi file in System Mode. Any help would greatly be appreciated. PS Please don't recommend Virtual Dub as the audio extractor, I never was able to get the hang of that program.
    Apr 2002
    The State of Frustration
    Then use Gold Wave to extract your audio. Simply load the original video into the program, and save it as a wave file.-- Voilá!
    Hello.
  3. Why is it I was always able to use TMPG before with the avi as the source for the audio and video and audio came out fine? Am I missing a codec of some kind?
    Apr 2002
    You may have changed one of your environmental settings. Of course, if you researched TMPGEnc on this site, you will find the TMPGEnc audio encoder is not the best one around.
    Hello.
  5. this wont help you at all, but go to settings tab/advanced/source range..
    tick the display audio box, and scroll through your avi... if you dont see the little green bubbles on the green line then for some reason tmpg is not reading the audio section of the avi... I am having the same problem with some of my files
    Dec 2001
    Sydney, Australia
    If you are encoding your audio through TMPGEnc then use an external encoder as Tommyknocker suggested, try tooLame, very good. This can be set up to work within TMPGEnc. Download tooLame from http://mikecheng.d2.net.au/layer2/toolame-02l.zip and set it up (very easy to do) through TMPGEnc's "Environmental Settings".
    Once set up you can forget about it. Do everything as normal and TMPGEnc will open up tooLame when you start encoding and it will set it up for you without any extra intervention from you. What does this mean for you? Better audio quality, less audio problems, no extra work from you except the 2 minutes to download and set up.
  7. Far too goddamn old now EddyH's Avatar
    Jan 2003
    Soul sucking suburbia! But a different part since I last logged on.
    to play devils advocate.... nothing wrong with Vdub for audio extraction.. what was it you had trouble with in that program? mebbe we can help..
    -= She sez there's ants in the carpet, dirty little monsters! =-
    Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more!
  8. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    If the sound is AC3 or VBR endoded MP3 then I prefer GoldWave like Tommyknocker suggested. Otherwise, Vdub is fast and efficient for extracting wav audio.
  9. Awesome, thanks for the help guys
