Ive got two different movies in SKVCD format. I have tried playing both on my many dvd players and the result on the stand-alones is that every 5 seconds or so there is a blank in the audio, but the video appears fine. On my pc no audio is detected at all.
Any ideas of what causes this? I burned it in SVCD format, but maybe Ive done something wrong.
Sunni
was the SVCD standard, compliant???
i.e. in Nero, there's a check box next to "make standard, compliant disc" that needs to be checked....
does your DVD player support SVCDs and xSVCDs at all??? https://www.videohelp.com/dvdplayers
you may end up having a non-standard, compliant xSVCD...so, you need to make sure your DVD player can handle the max bitrate you're using
btw, in TMPGEnc, did you downsample your audio from 48 Khz->44.1 Khz (audio tab)?? and you enabled 3:2 pulldown in tmpgenc, right (video tab)?? -
Sunni9676:
Very simply all of the templates at www.kvcd.net, including the SKVCD templates are not strictly VCD or SVCD compliant. They actually create XVCD's or XSVCD's. Your DVD player "may" only support VCD's and SVCD's that are in precise compliance with those standards. Templates from www.kvcd.net are not in compliance with the VCD or SVCD standards. -
Ive just burnt a sample of THE MATRIX (SKVCD) with nero and in the SVCD option when i draggged and dropped the sample in the box it told me it wasnt compliant so i just said ok burn anyway (as it couldnt convert without a nero plugin it told me)
it burnt and i stuck it in my CYBERHOME 400 i just bought from W.H.SMITHS for £49.95 and the film looks great so carnt wait to get the full one
trouble playing dvd
By speedoman955 in forum Newbie / General discussionsReplies: 7Last Post: 2nd Dec 2009, 08:08 -
Having trouble playing 1080p
By godvsnietzsche in forum Software PlayingReplies: 8Last Post: 24th Nov 2008, 19:09 -
trouble playing .avi files
By starkythesparky in forum Software PlayingReplies: 5Last Post: 12th Jun 2008, 23:54 -
Having trouble playing old vhs-c tapes
By Columbusbill in forum Newbie / General discussionsReplies: 5Last Post: 31st Dec 2007, 22:49 -
Trouble playing burned DVDs on my stand alone
By collin_stevens in forum MacReplies: 2Last Post: 12th Oct 2007, 17:51
