Hi
I have 7 small .avi movies that I would like on one Cd-R with a menu where I can choose either movie to play.
Can anyone tell me the best way to do this please.
Can I use Nero or EasyCdCreator?
Is there a "how to guide" somewhere in this site?
Thanks in advance
Results 1 to 9 of 9
You can do Menus with Nero but they're very basic. VCD Easy has a host of features for this kind of thing.
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
I am not goig to use VCD Easy ...
I want to burn my files as .avi / DivX files ... how can I do menus?
Any ideas ? -
Not a clue. You could do something with IE I'd imagine - but why bother ? As its to use in a pc the explorer is pretty much your menu.
you would need to use something like Flash or Director or Dazzler or something designed for interactive presentations, and write a "front end" where you can select a file to play.
You could also do it as HTML - make a web page that refers to the files on the disc, where you can click & play. That would be the cheapest and an easy alternative - all you need is Notepad and a HTML code cheat sheet.
Then you'd want to write an autorun file, so that when you put the disc in the drive, it would bring up your menu to start.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
You could use either of the following:-
Powerpoint.
Opus
Scala IC Designer.
Keep your eye open for the cds that come with magazines such as PC Pro etc, they sometimes include programs that will do it. Dazzle was on one once.TOMMO -
Keep your eye open for the cds that come with magazines such as PC Pro etc, they sometimes include programs that will do it. Dazzle was on one once.- housepig
Housepig Records
out now:
@edgler vess,
you expecting to play those .avi files on a standalone dvd player??? if so, you need to convert to (S)VCD.
only recently, a few dvd players started support MPEG-4
Avi on DVD with menu
By Regor21 in forum Authoring (DVD)Replies: 1Last Post: 20th Mar 2011, 12:58 -
Avi's to data DVD menu
By capa in forum DVD RippingReplies: 2Last Post: 9th Jul 2009, 11:08 -
Burning Multiple AVI's with Menu
By Candoo in forum Authoring (DVD)Replies: 12Last Post: 8th Jan 2008, 17:52 -
Avi with dvd menu upfront
By dvdfreak1971 in forum Video ConversionReplies: 5Last Post: 23rd Dec 2007, 21:44 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23
