(editted: new question)
In the Audio Tab on Instant Copy when you're choosing what to get rid of to save more space on the disc, there is an ACS5.1 and a DTS5.1
Is the ACS5.1 the Dolby Digital 5.1? If so can I leave the ACS5.1 and remove the DTS one and still get good surround sound.
I only use Dolby on my setup anyways, with my PS2 and my receiver.
Thanks!
I started out in Mount Clemens as a DJ
ACS(3)5.1 is the the dolby digital and you will still get good surround
DTS 5.1 is really, really good quality..hence, it takes quite a good chunk of DVD space...
however, you need a special decoder to play DTS, so unless you have that, the DTS audio track will just be silent. -
Genuine,
DTS is high quality like he said. there are some fundamental differences. Simple answer, remove DTS and your video quality is going to be much higher. DTS is typically like 800mb of space whereas dolby is more like 200-400 megs. Sounds is fairly comparible though. Why? DTS is higher bitrate, CBR (continuous, not any kind of variable bitrate) and has full sound spectrum on all 6 channels. Dolby (aka AC3, etc.) is VBR and has bass on the .1 channel and some of it omited on the other 5 channels. This gives a great space savings and overall average bitrate far less than that of DTS while having a comparible sound quality. That help?
HideOut
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 16:25 -
Question about playing DTS through AV receiver
By Spdngblt56 in forum AudioReplies: 7Last Post: 9th May 2010, 11:44 -
MKV2Vob DTS Question
By PM5K in forum Newbie / General discussionsReplies: 1Last Post: 25th Apr 2010, 04:18 -
DTS 15xx kbps to DTS 768 kbps and tsMuxeR question.
By Jared_ in forum AudioReplies: 0Last Post: 1st Jun 2009, 09:46 -
Question about hd audio in wmv hd - is it ac3/dts compatible?
By yoda313 in forum Blu-ray RippingReplies: 4Last Post: 12th Mar 2009, 16:12
