I am trying to burn my wedding video to DVD. I have an Adaptec VideOH! PCI in a Dell 2.4GHZ, 512M, 128M GeForce 5200, WinXP.
I used Movie Mill to capture video from VHS. The MPEG file plays great all th way through. I used ULEAD Movie Factory to burn DVD.
The problem is that towards the end of the video, the voice does not match with the video. It started out fine, but about 3/4 of the way through it get out of sync.
PLEASE HELP!!!
Thank you in advance,
Billy
Well what brand of discs are you using? I'll assume since its a Dell you've got a + burner, unless you added your own...it could be a problem with the disc(s), or your captured footage or even your DVD Player. I advise picking up one RW Disc so you can experiment and gradually eliminate possibilities without burning lots of coasters.
Yes, it is a DVD+. The first time I tried it with a Sony DVD+R, the second, I tried a Maxell DVD+RW. Any other suggestions?
I've had a similar problem with several different brands of -R discs. But when I push pause and then tell the player to play again, the voices magically go back to sync. Does anyone know if this might be the same problem?
