I keep getting errors on my encodes ..wavey lines wobbly hard to describe ...i can't do a screen capp cuase the error does not appear in the capped image
I capp using vdub
Picvideo 19 force yuy2 output ticked
Using this script
AVISource("C:\CAPTURE.AVI")
Trim(10000,12000).Fadeout(120)
Crop(8,2,338,558)
LanczosResize(352,576)
Encode using CCE 2.62
Elementary streams
Bottom field first
Zig Zag order
Average 2608 min 300 max 9000
Gop 15 image quality 25 no anti noise
Then using DVDlab author......
Play back in DVd player all wobbly
Now when i use the script without resize and crop in TMPGEnc the file is perfect.
Whats going on
Some thoughts i have
Field order ( have tried both ways)
Using a lower max bitrate
Is it possible that using the force yuy2 out put stuffs the encode cuase it is changing colourspace
I am really at a loss
When the file is view on Intervideo it plays without an error but when played on a standalone or on Power DVD the error occurs.
I have used and encoded coutless times but this is the first capped video conversion to DVd i have done ....I use good media (Ritek G04 Laser RW)
I have tried using other versions of Avisynth and other resizers (have even resied and frameserved with vdub...to no avail)..i have unistalled dvd lab and other edvd authoring software AAARRRGGGHH
Results 1 to 10 of 10
How long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
If you like Tekno download one of my tracks
www.users.bigpond.net.au/thefox149 -
I hate to do this but when i posted this 2/3 of the web was asleep
SO
BUMP
Please forgive me but i am going nuts i have spent two weeks on the problemHow long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
the error does not appear in a capped pic....
I have it narrowed done to a corrupt avi file i beleive as i have done testing on other capped avi with the same setting s but no problemHow long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
Well it seems that my theory of a corrupt file is wrong
To get it without errors i have to let tmpenc to the entire process which means going back to 30 hr encodes...until i solve this problem. Is it possible that my dvd burner is causeing the errors? i have uninstalled it but to no avail....still the problem persists........
It only happens when resizing/cropping.....is there a setting that need sto be iniaited??How long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
The problem is the error occurs on my TV also
So PowerDVD (same as ASUSXPDVD which is what iam using) shows the same error as one my TV.....
I am to beleive that is i deinterlace then i am taking away quality ....as it is ok for it to be interlaced??? maybe the video is progressive or teleclinded which i would doubt??How long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
I beleive Nelson37 is correct. The resizing is not correctly made for interlaced material. The fields should be separated, then rezised and combined back again to interlaced, or the easier way, just crop and add borders, do not resize.
Here's a script that won't rezise, only replace the cropped area with black borders:
Crop(8,2,338,558)
AddBorders(8,2,6,16)
Or even better (black out overscan area, block optimized for better comprssion):
Crop(8,16,336,544)
AddBorders(8,16,8,16)Ronny -
I have found the problem I have been using picvideo and picvideo has problems going to DVD standards
Trying to figure out what to call these symptoms
By jamesnearn in forum Newbie / General discussionsReplies: 8Last Post: 10th Sep 2012, 14:55 -
I call this Touch-Crash
By Blå_Mocka in forum Newbie / General discussionsReplies: 2Last Post: 18th Feb 2008, 08:56 -
A Holiday Call for Help!
By hexfield in forum DVD & Blu-ray RecordersReplies: 16Last Post: 18th Dec 2007, 21:28 -
Remake casting call
By Marco33 in forum Off topicReplies: 6Last Post: 5th Jun 2007, 02:18
