I am stumped. I would like to know is there any way to merge a dvd that is recorded on both sides and merge it one dvd+r. I have ISOBuster trial version, and have tried all the guides and it still doesnot work.
Here are my programs for use
dvd decoder
SmartRipper
dvdavi
TMPGEnc
isoedit
VobEdit
copy2dvd
computer spec.
P4 2.4 G
512 ram
16x Dvdrom
4\2.4\ write\rewrite
so pleae help me if possible.
Hi Tralix frustrating isn't it? I did my first double sided to one dvd-r yesterday following this guide https://www.videohelp.com/forum/archive/t162726.html
Do a test burn on a DVD/RW first as i managed to compile a dvd that played part 2 first and then went into the start of part one, so i just renamed the vobs in order and all worked out fine. The film was face off. Hope this helps you. 'O' and the quality is excellent (to me anyway). -
Honestly, if you really wish to do this, without all of the drama.. you must get TmpgEnc DVD Author..this software is so simple, even a child could do what you're trying to accomplish.
First, read this guide =
http://users.skynet.be/contra/dvddouble.htm
Then Rip one side of the DVD with Smart Ripper and put this into a separate folder..then repeat the same procedure on the second side of the same DVD, but place this file into a DIFFERENT folder.
Use DVD Shrink in RE-AUTHOR mode, to isolate the MOVIE ONLY, (if needed, be sure to keep the sub titles..but DO NOT compress the file.. do this with BOTH side A and side B. again, in two SEPARATE folders.
Now, open TmpgEnc DVD Author..follow the instructions given in the guide...input the Side A folder, DVD Author will automatically change the VOB files back into Mpeg2 files and place 'em into another separate folder..repeat the process with the Side B folder...DVD Author will place those Mpeg2 files into the SAME folder.
Then, DVD Author allows you to create Menus and chapters if you wish..then click OUTPUT.. it will then create a brand new DVD file..
Go back to DVD Shrink..place this new VIDEO_TS folder into DVD Shrink...now you can COMPRESS the file down to the point where it can fit on a DVD R.
You can then burn the resulting file with the burning program that comes with TmpgEnc DVD Author, or any other DVD burning software..
This works like a dream, without all of the hard work that can go into working with the IFO files and renameing the VOB files correctly. -
Originally Posted by GreatSinatraFan
you can skip the copy to hard drive as a mpeg file step
me,
i use power dvd to capture the name of each movie while it is playing
then after i import the first movie, (i clicked 'import dvd video' and add the first movie)
i create the menu with that captured movie picture from power dvd, (named track one)
then i go back and click the 'source setup' tab,
i then click the 'add new track'
then i import my second movie (clicking the 'add dvd video' button again)
i import the movie
then i add the second captured movie title from power dvd
for my second menu (named track 2)
then i output to my dvd folder (15 to minutes)
then i use DVD Shrink or ic7
to shrink the movie
this way you access both of your movies directly from the menu (and all of your original chapters from both movies instead of have 80 chapters of one movie)
now if you are doing the same movie you can ignore this
but there is no reason to convert your dvd to mpeg and back
so you can still skip that step
this is just a wasted step
plus there is no reencoding this way
it's more like remapping
Need Help with Panasonic DVD-LS83 or DVD-LS86 8" Portable DVD Player!
By Big C in forum Portable VideoReplies: 3Last Post: 1st Aug 2011, 17:35 -
Samsung DVD-HR753 DVD and HDD recorder rejected all my blank DVD
By undangltn in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Mar 2010, 12:34 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 08:14 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 17:59 -
DVD+/-RDL Playback on Yamaha DVD-C750, DV-C6770, and DVD-C950
By Big C in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Aug 2007, 08:59
