Is there a way to set the amount of time that each thumbnail plays? In the "create menu" section, when you click on the "display menu settings" button, then click the "motion menu" tab, it has various options for the motion menus. It would seem that the option at the bottom, which is called "length of motion menu" would be the option that you would choose. But in fact, that option does not control the amount of time the each thumbnail plays, it instead controls the amount of time between each loop before the thumbnail repeats itself! Other than THAT, the thumbnails only play for about 1 second, then with that setting, I can put whatever amount of time that I want before the thumbnail repeats itself. Is that some sort of backwards glitch that the program has? I cannot find a way to control the actual amount of time to make the thumbnails play. If anyone knows how to control THAT, please post the info!
