  1. Anyone know how to rip individual episodes off of a multi-episode DVD ?
  2. Banned
    Feb 2003
    Columbus, Ohio
  3. SmartRipper's "movie mode"
    or
    dvddecryptor's "ifo mode" (with multi-angle processing enabled in options)
    ..... should allow you to rip individual episodes...each one shows up as "angles"
    otherwise, you can rip the files "as is" with no multi-angles removed...
    smartripper's "file mode"
    or
    dvddecryptor's "file mode" (with multi-angle processing disabled in options)
    .... then, you can load the vobs into FlaskMPEG...since it has its own IFO parser, it will show you all the individual episodes as "angles" and you can choose which "angle" you want. you would then frameserve from FLAKMPEG to TMPGEnc and encode to (S)VCD.
    https://www.videohelp.com/dvdtovcdflask.htm
