I need to replace my DVD-Rom drive for my PC. What is the consensus here for the best RVD-Rom drive for ripping DVD's ?
Results 1 to 30 of 37
the forumsearch2000 by helpyourself, I use it myself, great results...
sorry feeling a little combative today... really I think that the consensus says that liteon makes the best rippers. Do a forum search, seriously...Turn your head and cough. -
Originally Posted by hotwings
Cheers -
any one that has 16x dvd reading capabillity
me, i use a samsung 16x 48x24x48 cdr dvd-rom combo drive ($70.00 )
so i can have the best of 3 worlds
fast ripping,
dvd burning (from my dvd recorder)
and fast cd burning -
Either the LiteOn163s or 166d 16x DVD drives will rip at speeds up to 11.5x for single layer DVD's. Do a search on pricewatch or pricegrabber and they usually sell for about $39 USD.
Be careful. Many DVD ROMs are locked at 2x by the manufacturers.
After a year of ripping at below 2x (90-120 min a disc) I bought a Lite On based on the advice of some forum members. I now get speeds of 4x-10x - 10-30 min a disc -
Lite-On, $48.00 at Wally World (Black face). Nice unit. I've paid a lot more for Sony's and other brands and found out someone put a governer on therm (aka locked).
Originally Posted by vance43211
you don't have to believe me
check out my very first posts
i don't know why it did that
but it did that a lot before i added an aspi layer -
It's not that I don't believe you, it's that it's not possible. Even with 15,000 RPM ultra 160 Scsi drives I don't think you could get 20X
I can barely get 10X with my IBM 180GPX and it is by far the fastest IDE drive you can get. -
I would say the GSA-4040B drives. I actually work for an OEM and have had a number of DVD drives for testing. They read and write DVD-+R(W),RAM, and are Ultra Speed drives capable of writing 16x CD-RW media which is sweet BTW. I am having a prob with DVD-R media but I figure it might be something that I'm doing. Media? Well see. Check out my post if you want. But any way, its been a killer drive so far and the movies that its created so far work perfectly.
chowSwift Kick In The Butt $1.00
"Everybody I know needs what I'm selling!" - Calvin -
My Pacific Digital DVD Rom gives me really good rip speeds.
SLICK RICKOriginally Posted by lordsmurf -
Originally Posted by thayne
I mean nothing else was diferent sep the DVD's I was ripping.. and it only has hit x15 one time.. mostly it's x6 or x8 ripping.. Hum, now that I think about it, all the x10 was when the drive was really brand new and near empty. Will be interesting to see what happend a few months from now as I fill it up with junk..
anyways.. as for a DVD drive to rip with.. Keep those slot load one's in mind. I mean even if it is not the fastest of the fast ripper wise, just being able to shove disks into is sort of cool.. Alot quicker if the cpu is on the floor or whatever.. -
Originally Posted by Greenspock
The problem mostly is that thing keeps dying on me.
For my other three PCs, I use Pioneer and not a single problem from any of them. -
Originally Posted by kenmo
Toshiba SD-M1612 or SD-M1712 with the hacked firmware is the best. Lite-On is also one of the best.
http://forum.firmware-flash.com/dl_firmware.php?category=1&manufactor=31 -
I have been using a Pioneer SCSI DVD-ROM drive DV-S303 connected to an Initio 930 SCSI card since May, 1999 for ripping and many other things. It has never died and has consistently ripped >5x (it is a 6x/32x drive). In comparison a newer Sony DR500AU DVD-writer configured as sec. slave has never been able to rip better than 3-4x, if that, can't read certain scratched DVDs that the Pioneer can, and gives "region code mismatch" errors on occasion (opening ONLY DVDDecrypter).
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i". -
This topic comes up a LOT and the outcome is always the same. LiteOn DVD-ROMs are the best for ripping. End of story
I have a Toshiba SD-M 1712 with hacked firmware, it's an excellent drive.
Originally Posted by crazeplaya
my creative and samsung dvd- rom are every bit as good as the lite-on
most 16x dvd rom are also
CD-ROM vs. DVD-ROM
By Judson in forum MacReplies: 10Last Post: 6th Apr 2012, 08:33 -
Blue ray ripping on dvd rom
By skorpinok in forum Blu-ray RippingReplies: 1Last Post: 4th Dec 2010, 08:31 -
Another DVD Rom issue
By dafoe in forum DVD & Blu-ray WritersReplies: 5Last Post: 16th Jul 2010, 11:49 -
dvd rom discs
By johnbud in forum MediaReplies: 3Last Post: 26th Jul 2007, 06:03 -
hd-dvd rom drive
By computerchuck in forum Software PlayingReplies: 6Last Post: 8th May 2007, 07:55
