I'm not able to capture audio using Virtual Dub. I can capture both video and audio using ATI's MMC 7.1 but for some reason not with VD. I've checked the capture audio box in Virtual Dub and have made sure the "line in" is not muted. I can get sound when recording but not during playback using MMC 7.1 nor Windows Media Player.
Everything else is working fine. What could it be?
I had the same problem. I was told that VirtualDub can not capture DV audio. Try AVI_IO.
In the tools section, they say AVI_IO is one of the best. Haven't captured from VHS. Try them both and see which one you like better.
Make sure your audio line is plugged directly into your audio card from the VHS machine and the audio "line In" on Windows Record is not muted.
I use VituralDub 1.4.7 all the time with my Happauge PVR to capture AVI's with no problem, even capture using Divx Codecs also.
I am using DVD, Laser Disc, SVHS, Hi8mm as the imput source. -
Vdum tell you to go into capture and back out then back in again ! Quite a lot of people could not get this to work.
Yeah, I checked all of the cables, even reseated each one. I've played around with all of the check boxes on both the recording and playback of my sounds. I've went in and out of Virtual Dub even restarted the computer a couple of times.
I'll give AVI IO a try tonight.
Thanks for all of the responses guys!!!
Virtual Dub say's No audio decompressor to decompress source audio
By s_joy09 in forum Newbie / General discussionsReplies: 10Last Post: 25th Dec 2011, 15:03 -
no options in audio compression for virtual dub
By jonbaker in forum AudioReplies: 9Last Post: 14th Feb 2010, 20:00 -
No Video In Virtual Dub, Just Audio
By AllenM in forum EditingReplies: 11Last Post: 3rd Oct 2008, 14:35 -
Virtual Dub Audio Not In Sync
By RKelly in forum EditingReplies: 2Last Post: 28th May 2008, 20:45 -
Audio problems with Plextor M402U and Virtual Dub
By nrsgzz in forum Capturing and VCRReplies: 4Last Post: 6th Sep 2007, 18:27
