I am attempting to capture video from my Sony Hi8 camcorder through my Avermedia capture card, with Premiere 6.5. I am successful to the point of creating the AVI file, however the frame size is only 320x240. When I fumble through the settings, I go into the Video Format area and attempt to change the 320x240 to 640x480 (which I believe it more representative of Hi8 quality) and it for some reason goes back to 320x240. Any ideas as to why? Am I doing something fundamentally wrong. Is 320x240 good enough for Hi8?
Your input please.
Thanks,
Gene
You have to check your camcorder manual to find out what resolution your Hi8 video is in. I would have checked for you, but I do not know what camera you own. Anyway, the prevailing rule of thumb is there is no need to capture too much higher above your camcorder's resolution, as the capture quality will not improve.
Hello.
Analog Video Capture - Which of the following methods is best?
By nharikrishna in forum Capturing and VCRReplies: 4Last Post: 30th Mar 2010, 22:46 -
Analog capture poll
By goggy59 in forum Capturing and VCRReplies: 3Last Post: 4th Jan 2009, 19:28 -
Best USB Analog Capture - Under $400?
By pjtgrizzly in forum Capturing and VCRReplies: 4Last Post: 31st Dec 2008, 16:45 -
Newbie question: cannot view/capture older DV tapes
By sinbarambam in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 9th Jun 2008, 07:48 -
Analog to Avi capture card
By ni-mh in forum Capturing and VCRReplies: 0Last Post: 25th Jul 2007, 16:16
