  1. I am having troubles getting audio onto a dvd-rw. I am trying to make a copy of the die hard triolgy. I was able to do the first one but the second and third are giving me grieve with the audio. I am using DVDDecrypter v 3.1.6 to decode the disks then using DVD2one v 1.2.3 to make it fit onto a disk. Then moving all the files created into Nero v6.0. I am putting all the files into the video folder of the compilation. I have tried using all of the sound tracks, one of the sound tracks and with or without the subtitles.
    Jan 2003
    In the bath
    So none of the soundtracks work, is that right? Do you just have silence?
  3. No audio at all, nothing but silence. I was able to make a back up of Braveheart and it works aok.
