are there any programs that i could use to capture a video image on my desktop?
thanks
Try Camtasia Studio. There is another program that works too, but I can't remember the name. I have it on my computer at home and if I remember to, I will post the name of it.
Here is a link to Camtasia Studio:
http://www.techsmith.com/download/studiodefault.aspdj matty b -
And Windows Media Encoder can do it for nothing.
Hello. -
camstasia studio cannot capture video and Windows Media Player doesnt work at all because it cant recognise the file type.
any ideas? -
If you have 2 computers this is easy if one of 'em has a video out..
Just jack the VIDEO OUT FROM YOU GRAPHICS CARD into you capture card, making sure to run a cable from the output of your sound card to the other sound card..
If not and you have 1 gig or more under the hood, you can capture directly using
HYPERCAM
or
Snagit
please enter to google to find TRIAL DOWNLOADS
Now a free product
Consider FRAPS.. It only captures the VIDEO however
so you would need ALLSOUND RECORDER
or TOTAL RECORDER ..both will caputre whatever is playing on your computer while it plays down in realtime..these aren't free and if you go this rout, you'll hav'ta capture VIDEO & AUDIO seperate and re-sync -
Keith, my young Jedi, I said Windows Media Encoder, not Windows Media Player.Originally Posted by Keith123Hello.
Trying to capture desktop running a screen magnifier
By Randy_the_Hack in forum Video Streaming DownloadingReplies: 1Last Post: 30th Jun 2011, 15:29 -
Capture desktop of another PC/notebook
By cardenal in forum Video Streaming DownloadingReplies: 1Last Post: 26th Jul 2009, 23:55 -
Capture Desktop screen on a streaming format?
By therock003 in forum Video Streaming DownloadingReplies: 4Last Post: 9th Feb 2009, 14:24 -
What program can I used to Capture what i'm doing on the desktop (monitor)?
By Goldman123 in forum Newbie / General discussionsReplies: 3Last Post: 27th May 2008, 15:02 -
Is there a software that i can Capture my Desktop Actions?
By hgtvg in forum Newbie / General discussionsReplies: 3Last Post: 22nd May 2007, 20:10
