All,
If any of you have a NEC 1300 can you tell me where i can get some cheap DVD-rs that are compatible with this drive (i cant flash my drive - firmware for some reason).
Im in the UK and the best deals i have foud are with ritek but it is still over £1.20 per dvd in packs of 100s.
thanks
What firmware do you have? I have 1.05 and I can burn Princo 1x DVD-R's with out any problems. I got them for $1 each. Although my next batch of discs will be Ritek 4x becuase they seem to have better reviews in the DVDmedia list. Even though I haven't had any problems with Princo I will spend the extra $0.2 per disc on Ritek 4x just in case. Oh also for the 4x speed.
Check those websites that advertize on this site. -
It could be that Princo may or may not work depending on the manufactureing batch??????? To be safe that's why Im going to switch to Ritek which has been listed as working on NEC drive.
Where did you get the 4x and what are they called? I'm in the US, btw. I swear, I haven't seen ANYONE agree on media. I just want to know a better than x1 speed burning disc -R that isn't insanely expensive. I'm currently using the GO3's at 1x.
Take a look at refreshcomputers.com, they are based in Hampshire (about a 5 minute walk from me). They do carry a fair range of media in most formats, I use Ritek or another nameless one I forget, in my NEC ND1100a, but of course thats DVD+R, and I paid £1-20 on saturday for some. There seemed to be very little, if any difference between +r and-r prices the last time I looked.
William -
http://www.ukdvdr.co.uk/acatalog/copy_of_DVD_R.html and http://www.moreforyourmonkey.co.uk/default.php?cPath=6 and http://www.ebuyer.com/customer/products/index.html?cat_uid=25&subcat_uid=105 are the cheapest I've found for DVD-R media
As for what type of DVD-R to get, I'd like to know that too
You might wanna check out auctions too... http://www.ebid.co.uk http://www.ebay.co.uk http://www.qxl.com http://www.freeserveauctions.com -
You could try here
http://www.blankdiscshop.co.uk/
They have some great bargains
Cheap DVD-R Any Good?
By adalect in forum MediaReplies: 32Last Post: 28th Mar 2010, 22:45 -
[rant] cheap DVD case
By impmon2 in forum Off topicReplies: 2Last Post: 29th Oct 2009, 10:09 -
Where to get DVD DL disks cheap?
By Jorge in forum DVD RippingReplies: 44Last Post: 21st Sep 2007, 10:38 -
NEC DVD Drives
By RapidRio in forum Newbie / General discussionsReplies: 1Last Post: 5th Jul 2007, 14:13 -
decent dvd recorder for.... cheap
By zamac_man in forum Capturing and VCRReplies: 4Last Post: 22nd Jun 2007, 14:00
