Well this one is very weird for me. I'm able to use the 007 version with no problems so far, but can't seem to be able to split an AVI file correctly.
My movie is around 3h long, so my AVI file is 2.69G. In the filter tab, I'm entering 90 minutes 00 seconds for the "split time". ffmpeg creates the 1st split file correctly (about 1.31G) but the second file end up with more than 2.69G....bigger than the source !. I'm probably missing something very elementary...but just can't figure it out.
If ffmpeg is not the right software to split this AVI file, which one should I use ?
Thanks for all your help,
JR
a158832Guest
DigitaleeGuest
Well I seem to be having the same problem. Using ffmpegX 0.0.7d with the latest binaries. I'm trying to split a 740MB file into 700+40 for CD archiving. The specs on my AVI are:
Video: XVID, 503x364, 30 fps & mp3
Audio: 128 kbps, 48 kHz Stereo
It makes the first chunk just fine, then the second one keeps going for along time then getting info on it shows it to be a 760MB file and rising, then ffmpeg crashes. The second part upon reviewing starts over from the beginning of the file again.
Can anyone shed some light on this?
Thanks a bunch!
How to split a .TS video file based on time (not file size!) ?
By Michael REMY in forum EditingReplies: 4Last Post: 19th Sep 2020, 18:32 -
how to split mkv file and subtitle file to play on blu ray via hdd usb
By julie_152 in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2009, 11:28 -
Split Mpeg or convert to AVI then split. What to do?
By oldfart13 in forum Video ConversionReplies: 4Last Post: 24th Mar 2008, 00:00 -
split one file avi in two
By Jomapil in forum Newbie / General discussionsReplies: 4Last Post: 8th Mar 2008, 14:13 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 12:49
