Hello...I have downloaded some video (.avi) files and when I try to watch them using Windows Media Player it will not play them and states, "cannot play back file. format is not supported" How can I go about fixing this. Also, after I do get past this first problem...how can I convert them to MPEG so I can burn them to DVD/VCD to play in my DVD player? Any help would be greatly appreciated. Thanks !
First download Gspot to determine whether you have/need the correct codecs.
http://www.headbands.com/gspot/download.html
Then follow this guide for conversion
https://www.videohelp.com/tmpgenc.htm
And,this one for burning
https://www.videohelp.com/vcdeasyhowto.htm
If you want to do XVCD instead
https://www.videohelp.com/tmpgencxvcd.htm
Check your DVD player for compatability.
https://www.videohelp.com/dvdplayers"Today is only yesterdays tomorrow" -
I am new to making svcds from avi's and im having a problem with DVD2SVCD v1.1.3 build 2. When i change modes into avi to svcd mode, under the misc tab I am unable to check "convert divx 3 to divx 4". Im pretty sure I have installed all the codecs that were said to be installed if there was ths problem. I am also using Cinema Craft Encoder v2.5.
What should i do?
Mkv & FLV Conversion Trouble
By Simmons in forum Video ConversionReplies: 1Last Post: 9th May 2011, 12:55 -
Trouble Converting TS to MPEG
By Somebody2 in forum Video ConversionReplies: 2Last Post: 14th Jul 2010, 18:30 -
Trouble converting mpg
By Jeffrey99 in forum Video ConversionReplies: 4Last Post: 13th May 2009, 06:59 -
Trouble converting(demuxing)
By VJep in forum Video ConversionReplies: 5Last Post: 24th Dec 2008, 23:43 -
Trouble with audio to rear speakers (off & on)
By heyjjjaded in forum Media Center PC / MediaCentersReplies: 0Last Post: 20th Apr 2008, 22:50
