Hi Im relatively new to encoding to SVCD, Im from australia and have had no problems with encoding and burning PAL DVD's. On the other hand i have trouble with NTSC DVDS. I encode using TMPGEnc using the ntsc template and burn with nero clicking on ntsc. The result on by DVD player is jerky video. I dont have any problems playing an original ntsc dvd on my player. Any suggestions on what the problem may be?? Also If anyone has the regpatch for tmpgenc can u please email it to me. Thanks
It sounds like your field order could be wrong. Go to the advance tab(i think) and change it to the opposite one you used.
NTSC DV from Final Cut Pro to NTSC DVD Problems
By Killer3737 in forum Video ConversionReplies: 1Last Post: 9th May 2011, 12:25 -
PAL/NTSC DVD/VCR combo that will play DVD+R's w/o A/V synch problems?
By wetcamelfood in forum DVD & Blu-ray PlayersReplies: 12Last Post: 12th Jan 2010, 16:25 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
Problems with CMD-850 PAL to NTSC conversion
By vwy33 in forum Video ConversionReplies: 18Last Post: 31st Jul 2008, 07:55 -
Problems with Documentary trying to use both PAL and NTSC footage
By Lucy in forum MacReplies: 5Last Post: 24th Jun 2008, 15:57
