Hi guys !!!
I have followed the FOOLPROFF method and all was really smooth till i came to the section when i have to pulldown the 23 FPS to 29
(my source is 23 FPS).
After trying and using both versions (WinXP compitable ) and DOS versions of pulldown.exe i have picture shaking.
Its like do small vibrating down and up.....
Anything have expirienced this?
If so ,u might also know how to fix it?
Its possible that you had the encoder set to interlaced frames, or that the encoder didn't properly set the prog_frames flag. Try getting the gui for pulldown.exe and setting the prog_frames flag to progressive and the prog_seq flag to interlaced. This is the proper setting for an ntscfilm encoded (23.976fps) movie.
Now you didn't say what format you are making. If you are making a SVCD and using a 16:9 aspect ratio than there is nothing you can do. Very few hardware players support 16:9 SVCDs.
BTW: Does it only shake on a hardware player or does it do it on a software player on your pc too? -
Its shake on pc too,right after i got m2v file.
I don't remember but i think i used 16:9 so u say i need to use 4:3? -
It will do this if you used the "PROG_SEQ P" command switch.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Ok guys,thanks !!!
Its solved the prob.....
damn CCE is great encoder...
i just did XviD to SVCD and they same quality when i play them on PC. -
Guys ,another question on this subject :
I Pioneer DV-355 do supports 16:9 but my tv is not wide screen...
so i need to encode it only in 4:3 aspect ratio? -
No, you can still benfit from encoding in 16:9 even without a widescreen television, but I do not believe that 16:9 is supported in the SVCD standard. Use it at your own risk.
how to convert alternate-frame 3D into SBS 3D ??
By mauslyon in forum Video ConversionReplies: 1Last Post: 10th May 2011, 08:23 -
Convert 30fps to 24fps skipping every 5th frame?
By DragonQ in forum EditingReplies: 7Last Post: 29th Jan 2011, 03:11 -
convert .mkv with non-standard frame rate
By Conrad007 in forum Video ConversionReplies: 2Last Post: 20th Jan 2011, 11:50 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
Convert m2ts with frame interpolation
By jdark in forum Video ConversionReplies: 3Last Post: 12th Sep 2009, 12:10
