  1. Hi all,
    I created 2 Mpeg 2 files using Ulead Video Studio 7. They both play fine on all my players, but when I join them in TMPGEnc the resulting file has no sound.
    Is there an easy (hopefully free) MPEG 2 joiner out there?
    Thanks!
    Dingo Magoo
  2. Why not use VS7?If the files are identical then VS7 will "Smart Render" and speed up the encoding process.
  3. i guess I haven't figured out how. I know how to split clips in VS7 but not join them.
    Apr 2002
    The State of Frustration
    Put the first one on the storyline, then the second. Render as normal.
    Hello.
