Made another thread for the TMPGEnc. I have another one concerning the EO Vidoe thingie, if you can help with that here:
https://www.videohelp.com/forum/viewtopic.php?t=172542
In the meantime, I'll give this here a try.
I start the program.
Dealing with one problem at a time, and using the Instruction Guide the first problem is:
How Do I Access the Project Wizard?
More problems occure after that, cuz I have used the PW once before, but since I'm starting from zero again... I need to find out how to get the PW thing going again.
Thanks for any and all help!
Here's another problem I'm having with changinge my AVI file into MPEG.
I go to the Vidoe Output... click Browse...... choose the movie and it says:
File "C:\MyStuffnJunk\GTO - the Movie.avi" can not open, or unsupported.
I can play the movie fine on all my movie players...... what am I doing wrong?
Results 1 to 11 of 11
under the File menu, you should see an entry for the wizard.
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Originally Posted by JohnCrichton
File "C:\MyStuffnJunk\GTO - the Movie.avi" can not open, or unsupported.If you get an error message when opening like file unsupported or can not open or is not supported
or you get an empty(black) video preview window
or the video look wierd in the video preview window like green or purple or pink
Try first to change the directshow codec reader priority settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 or to the top of plugin-list and try open the video.
P.S. If this posts helps on any way, please have your brother Mike give me an autographed copy of Jurrassic ParkHello. -
I'm John Crichton"... the astronaut!" from Farscape. No relation to, Mike unfortunately. That and I'm in another galaxy currently.
Alright... I don't have TMPGEnc Plus... no option to select the Wizard.
Changed the Direct Show Multimedia thing to Priority 1 and at the top of the list. Same error message.
Is this because I don't have TMPGEncPlus? -
Scratch that... found another version on my comp that's got the Wizard.
Attempting to convert again.... I'll let ya know what turns up. -
Still no dice..... coming up with the same error message even after a quick trip through the Wizard.
File "C:\MyStuffnJunk\GTO - the Movie.avi" can not open, or unsupported. -
In continuing my bid for "Most Problems Had", I've also tried Virtural Dub. A program that's suppose to help with the Audio.
I go to FILE
Open Vide File
Selec Video
Then I get:
Couldn't locate decompressor for video format 'DIV3' (Microsoft High-Speed MPEG-4 V3 [Hack: DivX Low Motion])
Virtual Dub requires a Video For Windows (VFW) compatible codec to decompress video. DirectShow codecs, such as those used by Windows Media Player, are not suitable.
*sigh*
Saaaaay......... what? -
Thank you.
AVIcoded says
V. codec name - DivX v3MPEG-4 (Low Motion)
A. 1 codec name - MPEG Layer-3
Snow now... do I want:
ASF Codec(MPEG-4 V1/2/3) ASF / MPEG-4 V1/2/3 Codec.
or
DivX3.11 The old DivX Codecs so You can play and convert downloaded AVI DivX
movies.
Btw, I can't thank you guys enough for pitching in like this. I've been plugging away at this problem for days now. -
Fine... if I can't get an answer on this, I'll just get both codecs. Be back with the results....
Well, I'll be........... thanks to the "DivX 3.11" Virtual Dub is actually working......
More later.... after this begins the pain of trying to convert AVI to MPEG.
That should be about another week's worth of work.
More questions to come. And thanks!
2 Cameras, lots of problems.
By Benhermies in forum EditingReplies: 2Last Post: 12th May 2009, 12:01 -
[SUPER] iPod on TV conversion problems (heavier and lots of squares)
By Horrigan in forum Video ConversionReplies: 9Last Post: 24th Mar 2009, 23:02 -
Lots of problems that transcends different sections.
By guy_edwin in forum Newbie / General discussionsReplies: 4Last Post: 20th Dec 2008, 04:36 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 18:37 -
Daytek DVR-P30: lots of 'fails' when erasing, lots of nothing when recordin
By buzzinhornets in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Jul 2007, 15:43
