I have a digital camera which can make .mov movies (quicktime) I'm able to convert the files to mv2 and wav 'with Tempenc but after creating a DVD or VCD with CopytoDVD the movie won't play at my home DVD player. Can anyone help me?
thanks
John
Results 1 to 9 of 9
does your player even support DVD-R or DVD+R????
look here: https://www.videohelp.com/dvdplayers -
Yes my DVD player supports both -r as + r. I've already copied a few dozen of my DVD movies and they all work fine.
Authoring: through Tempenc and Tempenc DVD -
No I can't play the files in my computer. Are there other ways to convert a .mov file? Another program I mean?
i'm not referring to the actual files on your hdd...
i mean once you create your DVD, load it into your PC DVD-ROM and play it with powerDVD/winDVD (or any other software DVD player)...
...so, can you play your DVD on your PC this way??? -
No I can't play these files. Sorry for the misunderstanding.
Is there another program? -
take a look at this guide: https://www.videohelp.com/tmpgencdvd.htm
To convert from QuickTime MOV videos you must download the QTReader.vfp and copy it to the TMPGEnc folder.
btw, are you just simply burning the .mpg directly onto the DVD as DATA???
you need to author your .mpg to DVD VIDEO....
convert .mov or vob file to .flv
By Giacomo in forum Video ConversionReplies: 5Last Post: 3rd Feb 2011, 12:03 -
How can I convert a .mov file that has been tampered with?
By ktconverter in forum Video ConversionReplies: 5Last Post: 30th Jul 2010, 19:38 -
mencoder wont convert the complete file, mov to avi|mov
By bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 07:42 -
convert MOV file?
By AlanHK in forum Video ConversionReplies: 3Last Post: 18th Sep 2008, 06:27 -
Best way to convert .mov(QT) file to an .avi file...... is?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 3rd Sep 2007, 21:05
