  1. hey i need some dude that can send me
    his own!! templats from TMPGEnc
    just like thise
    DVD (NTSC).mcf
    SuperVideoCD (NTSC).mcf
    SuperVideoCD (NTSCFilm).mcf
    SuperVideoCD (PAL).mcf
    VideoCD (NTSC).mcf
    VideoCD (PAL).mcf
    But your own one made for good qulaty
    i hate bad rips a waste of time
    so can some one please send me his costum made templats
    MUST BE FOR GOOD QULATY RIP AND CONVERSION!!!!
    sorry for the bad english... (
    BG
    Jan 2001
    Vancouver/Portland
    Just load the specific template you're aiming for (i.e. SVCD, VCD...) Then alter the settings (you should load the 'Unlock' Template too), and mess around with bitrate, the filters, and whatever else to fit your demands.
    Feb 2001
    Berlin, Germany
    Jeomite is right. There is no "best template" at all. If you don't want to "waste your time", contact your local DVD dealer. Otherwise you have to do some tests. If you don't care about filesize, use max quality settings, i.e. SVCD 480x480/576, CBR ~2500. If you don't care about time, use noise recuction HQ mode.
  4. Member adam's Avatar
    Sep 2000
    I would not recommend using any noise reduction on a high quality source. It does not increase quality it decreases it.
    Minimal noise reduction is ok but even the default TMPGenc settings are way too much for something like a dvdrip.
  5. well i will try to mess arounf whit it
    thanks m8's
    Bg
  6. how do i unlock VideoCD (NTSC).mcf
    so i can edit it
    i cant make a hole new one and then start fron scrach
    i need to make some small adjustments
    to the all redy made file
    VideoCD (NTSC).mcf
    ho do i edit the VideoCD (NTSC).mcf
    and alle the other
    (i have made backops of then just in case hehe)
    Bg
  7. Member adam's Avatar
    Sep 2000
    Scroll up, Jeomite already posted how to edit templates. First you load the template you want to edit in TMPGenc. Then you load the unlock template located in the extra dir. Now all settings will be unlocked.
