Hi i'm trying to get my anime episodes converted into dvd format. I've been reading all the tutorials, but from what i read it seems to be only for one movie file. I'm trying to get at least 5 different episodes to be played on the dvd player. I tried to join the 5 different avi files into one big one but it doesn't work because of the bit rate or something. So what can i do? Should i convert them into mpeg first then join them? Thanx
There are guides and posts about your problem. What software are you using ?. When you say you cannot join the avi files together what happens ?
HI Mate,
First off download TMPGEnc and Ulead Movie Factory.
Put the avi file into TMPGenc and run it using the wizard. This will create an mpeg.
Do this for each of your avi files.
Once they are mpegs open up ulead movie factory.
Here you can create a new project. Add your 1st file, then 2nd and so on. This way you can add quite a few mpegs.
I cant remember the link but try looking in the guides for the ulead movie factory guide - its very good!
Help me, I'm a newbie
By Shadowmistress in forum Off topicReplies: 2Last Post: 19th Jun 2011, 08:54 -
Hello from Newbie
By markwaugh in forum Newbie / General discussionsReplies: 4Last Post: 11th Apr 2011, 13:13 -
Newbie needs help!!!!!! DVD to xbox 360 streaming
By JohnS719 in forum Newbie / General discussionsReplies: 0Last Post: 22nd May 2010, 08:38 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 09:43 -
Newbie here, which camcorder should i get?
By defectivelasagna in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 16th Aug 2009, 12:52
