  1. Hi all,
    I have lots of avi files i want to make into mpeg 1 then i can make a dvd version.
    The problem is when i try to convert it using the Wizard it gives me an error stating ''Cant Load P3Package.dll''. I have no ideas what this means!
    I have also tried loading it directly (i.e. close wizard then browse, find avi file, open etc) but it says ''Not enough Memory''.
    Does anyone know what any of these mean?
    I have installed a XviD Codec to change the avi to DIVX as someone suggested that might be it but it hasnt worked.
    Thanks all - im at the end of my tether!
  2. Update - I have figured out why it kept erroring with the .Dll error - i am converting a ntsc file and i kept trying make it pal (im in the uk).
    This worked however it then said the same as the non-wizard error ''not enough memory'' - any ideas?
  3. Have you run the AVI through Vdub to check for bad frames ? I have had a few AVIs that TMPGEnc threw back at me so I've recently started to frameserve using vdub and its worked like a charm so far
