Greetings,
I have a Hyundai HDP 550S DVD player connected to an Onkyo TXSR-600 AV receiver. Occasionally, when certain sounds occur on some DVDs, the Onkyo will reset, and when you turn the Onkyo back on, the word "protection" scrolls across the display before it resumes operation. I am assuming this is because of the input signal being sent to the optical input from the Hyundai. The problem is sometimes repeatable with the same disk scene and sometimes not.
I wonder if it's a problem with my el-cheapo Hyundai DVD player transmitting incorrect AC-3 signals or if the Onkyo is just flaky?
The problem is that I started using them both at about the same time, so I have no history of using the Onkyo with any other DVD player.
Has anybody else had any similar experiences with any of this equipment, or any other equipment for that matter?
I know, I know. I should buy a decent DVD player anyway, and I will. But I really don't think I need to if the Onkyo is just too sensitive.
Results 1 to 1 of 1
Lost Audio on kid's video project. Confused about : .HO. .adv, .HDP files?
By tmh in forum AudioReplies: 2Last Post: 7th Dec 2011, 18:50 -
Can the wdtv or asus hdp-r1 play vc-1 in an mkv container?
By sampalmer21 in forum Media Center PC / MediaCentersReplies: 1Last Post: 11th Nov 2009, 16:16 -
I need a free REGION HACK for a Hyundai HDVC - 001
By Petrovich in forum DVD & Blu-ray PlayersReplies: 1Last Post: 12th Dec 2007, 10:11 -
Connect TV to AV RECEIVER
By alintatoc in forum Video ConversionReplies: 3Last Post: 4th Oct 2007, 15:53 -
Hyundai 42 inch Plasma
By hummer in forum DVB / IPTVReplies: 4Last Post: 6th May 2007, 11:20
