I've encoded an XSVCD using a bitrate worked out by this site's BitrateCalc applet to fit nicely onto 2 x 80min CDs. That all went ahead just fine and then I cut the one MPG file it made using TMPGEnc into halves to burn to CD-RW.
Now I have two MPGs. One at 743.8MB and the other at 728.9MB (I used VBR obviously). When I go to burn them to disc using Nero 6, I get the "there is too much data to fit on this disc" warning message. "Do you wanna try overburning?".
What's wrong here? According to this page: https://www.videohelp.com/forum/userguides/135642.php I should be able to fit at least 797MB on the disc without a drama.
Why does Nero report an 850MB compilation equating to a play time of 84:43 (or something like that) while it's burning?
Is it something to do with the resolution of the video? I made it XSVCD so I could get 720x576 resolution - but that shouldn't matter to the size of the file should it?
Cheers,
DRP
I have had this problem before and I found that when I cut the file using tmpegenc, I forgot to select "Mpeg-1 Video CD (Non-Standard)", this is the key as the size depends on what you select here and it will be bigger if you select standard video cd.
I have been converting and burning XVcd's successfully and have not had any problems, only thing is I have to stick to 352*240 resolution as MY Toshiba SD 2800 does not support other higher resolutions for Xvcd's. -
Originally Posted by Cataphract
I can't believe how much of a d*ickhead I am for not working this out myself!
Video won't fit on dvd
By chevyfever in forum Video ConversionReplies: 5Last Post: 6th Nov 2009, 07:50 -
USB stick won't fit in printer
By csaag in forum ComputerReplies: 4Last Post: 25th Aug 2009, 20:54 -
How to fit the large size picture to the smaller size for print?
By coody in forum ComputerReplies: 7Last Post: 1st Apr 2009, 08:46 -
tsremuxer produces m2ts files that won't play sound
By runLoganrun in forum Video ConversionReplies: 2Last Post: 8th Dec 2008, 13:31 -
why won't my avi fit on a dvd-r
By bigwheels103 in forum Newbie / General discussionsReplies: 3Last Post: 24th Oct 2007, 21:08
