Hi, I have a problem with a DVD I authored a couple of days ago. I captured through firewire into Ulead Videostudio7 (I think- it came with the A06). It captured fine, I put a menu in etc- looked great. The problem is that it is a 90Min dvd, and Ulead split it up into 71 "chapters" of around 90 seconds. when the Dvd is played, every time it goes into a new "chapter" it freezes for around one second and then continues. Other than that it looks great. I'm at work at the moment so I will edit this once I get home to find out exactly what program it is. I have used VS5 before and had no problems like this with it- though that only got used for VCD's
Originally Posted by hoyboy
That's what happens when an *independent* video chapter stops playing and then the next *independent* video chapter begins playing.
To stop the freezing, you'll need to tell Ulead Videostudio 7 not to split your source video into multiple files.
Instead, render out a single DV .avi file.
Then encode the final, edited DV .avi file to a single MPEG-2 file.
Then enter your DVD authoring module and import the single MPEG-2 file.
Create the chapters within the single MPEG-2 file.
In that way, when you create your chapter menu you'll be able to click any of the chapter thumbnails and the video will play continuously without freezing.
Jerry Jones
http://www.jonesgroup.net
Nero Recode 2 Chapter Mark "Creep" vs. Original DVD
By CobraPilot in forum DVD RippingReplies: 4Last Post: 16th Feb 2012, 22:29 -
"Bit Error" when playing AVIs on set top box - video freezes
By MLS in forum Newbie / General discussionsReplies: 1Last Post: 15th Jun 2011, 14:26 -
MPCHC puts a chapter "subtitle" on the bottom of my mp4s
By brianp6621 in forum Software PlayingReplies: 2Last Post: 19th Oct 2009, 12:35 -
Re: making "live" chapter button with windvd creator 2
By tomcat862 in forum Authoring (DVD)Replies: 0Last Post: 28th Feb 2008, 12:13 -
dvdauthor problem "chapter doesn't exist"
By ecc in forum Authoring (DVD)Replies: 2Last Post: 28th Jan 2008, 08:54
