  1. I currently have an old Asus A7V with a 1.4 GHz TBird and 512 Megs of Ram. My VCD encoding times for a 720x480 movie in TMPGEnc are just under double run time (45 minute movie = 1hr 25min encode time).
    I'm looking at doing an upgrade to an Asus A7V600 and I want to use 512 Megs of DDR Ram.
    What processor should I expect to be able to perform at run time (45 minute movie = 45 minutes encode time)? Is this actually possible yet?
    Thanks,
    BG
    Seaside, CA
    Bgrieb:
    My own encoding tests show almost a direct corelation with processor speed. So, provided you do not change any encoding parameters at 2.8gig processor would produce encoding times of approximately half the time it currently takes you. I have not seen any significant encoding time difference by increasing RAM capacity from 256meg to 512meg.
  3. Originally Posted by bgrieb
    Thanks,
    BG
    I am currently encoding SVCDs, using TMPGEnc, and I need 1hr encode time for 1hr movie. My system specs are:
    Asus A7N8X Deluxe
    Athlon XP 2400+
    Corsair 2x256MB PC3200 DDR (2-2-2-6)
    I hope this helps.
    universe
    i use main concept on a pentium 1.6 . it takes 30 minutes to do a 1 hour movie.
    Mar 2003
    Laredo,Tx
    i got an AMD 1900+xp processor, 512 MB ram, and 1.6 GHZ, i can do VCD with TMPGEnc at real time, and CVD and SVCD a little bit slower than Real Time. But With Cinema Craft Encoder, Using One Pass i can finish a 1 hour movie in about 25 minutes making it a vcd. If i make a cvd or svcd on CCE it usually goes at speed of 1.769, which is pretty fast, so its almost half the time of the movie. ex: 1 hour movie will encode, in 40 minutes.
    An all in one guide for DVD to CVD/SVCD/DVD by cecilio click here--> https://www.videohelp.com/forum/userguides/167502.php
  6. No way man... you need to go dual! Pure sweetness.
    Swift Kick In The Butt $1.00
    "Everybody I know needs what I'm selling!" - Calvin
    Baltimore, Maryland
    With my system i can encode in real time or faster in TMPGEnc and cce and main concept i can do real time also but the Q is not par with tmpg and cce. i have not tried other encoders but it took about 40mins to encode Zombie SE (which is about 1hr27mins long) in cce cbr svcd.
    [ = Check out my band @ www.samadhirock.com = ]
