Sorry if this has been posted before, but the search function on the forums is currently disabled.
When trying to use the: "Encode hi Freq" checkbox on the option tab (ffmpegX v0.0.7d) the video conversion fails and it goes straight to the audio conversion. output as follows.:
Encoding started on Fri Aug 8 12:01:49 CST 2003
mpeg2dec-0.2.1 - by Michel Lespinasse <walken@zoy.org> and Aaron Holtzman
Using altivec for IDCT transform
Using altivec for motion compensation
Frame rate code = 103823
MPEG in libvo = 82224 aspect_code=83496
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
/usr/bin/mpeg2enc: invalid option -- h
Been using an earlier version for months without any problems. Installed 7d recently, and this is happening on all my conversion attempts.
BTW, I am converting PAL DVD to PAL SVCD
Hope someone can help.
thanks
Audio encode error in MeGUI
By fatcharlie in forum Newbie / General discussionsReplies: 6Last Post: 14th Apr 2011, 11:43 -
Megui error encode !
By whitebeard in forum Blu-ray RippingReplies: 0Last Post: 17th Jan 2011, 04:46 -
Audio freq response on various DVD speed settings? - HELP!
By will7370 in forum AudioReplies: 2Last Post: 12th Jul 2010, 15:05 -
Cannot Encode, Audio Error
By kidcash in forum Video ConversionReplies: 4Last Post: 19th May 2008, 02:18 -
(Completed): MMC capture results in 44100 sample freq instead of 48000.
By palouse in forum Capturing and VCRReplies: 14Last Post: 23rd Oct 2007, 15:47
