  1. What happens if you don't set the number of gops for DVD pal (15)
    Would you have play back probs on a standalone but it would play fine on a PC what would you expect to happen?
    How long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
    If you like Tekno download one of my tracks
    www.users.bigpond.net.au/thefox149
  2. is there no one who can answer is is half of dvdrhelp asleep??? damn southern hemisphere and international time lines....
    I think PAL limit is 12, but could be wrong. Maybe it is 15.
    Maybe it's just PAL suggestions to go 12 due to 25fps/50hz.
    I know NTSC is 18, but suggested to go 15 due to 30fps/60hz.
    Anyway, too many GOPs will prevent playback.
    That's not a DVD video file at that point.
  4. Member DJRumpy's Avatar
    Dallas, Texas
    Max GOP size is 15 frames ( 30 fields) for PAL, and 18 frames (36 fields) for NTSC. If you set it too high, you only risk the chance that your standalone player won't play it.
    Impossible to see the future is. The Dark Side clouds everything...
  5. My problem is I have authored with dvdlab and it plays smotthly no errors on my pc but on any standalone it's all wavey (picture hard to describe)
    It is totally racvking my brain please refer to my other post Plays fine on pc but not in player(s)
    I am usgin good media as i have used the same media to back up my dvd's I am really at a loss
  6. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    I would guess the Gop is the problem. i had trouble with TMPGEnc accidentally creating the odd 16 frame GOP, and my authoring software just booted it straight out.
    May 2001
    If you have the full version of Bitrate Viewer, you could actually determine your GOP struture. Or, load your file into ReMPEG2 and check its log - I believe that it reports the GOPs.
    If you don't have a compliant GOP structure, no authoring package should even accept it (GOPs are not optional for DVDs).
    Yeah, you "night-timers" have a problem with time!
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
