Results 1 to 11 of 11
  1. I just burned my second dvd using this media, and it failed with this error in copytodvd
    13:43:08 error Write failed
    13:42:21 error (WriteSector) Failed: Code 03 90 92 [Unknown Medium error
    This is the first error that I have received burning dvd's, (this being the 4th dvd that i have done )
    What is the problem here? is it a media problem or something else?
    Is it real or fake Maxell?
    If the MAXELL logo isn't emblazened on the top, it's fake.
    Last I saw, it was blue on top too, and a deep purple (almost brown) on bottom.
  3. It is maxell. silver on top, says maxell, deep purple on bottom, tried to backup minority report, only the main movie
    Where exactly does it "say" Maxell ?
  5. It says Maxell right on the top of the DVD
  6. I just ran DVDINFOPro on it and this is what it told me. I guess it wasn't maxell media after all, but is that the problem?
    Media Information
    Region information N/A not a DVD-VIDEO
    Media code/Manufacturer ID RICOHJPNR01
    Formatted Size Blank
    Total Size 4.38GB(4.70GB)
    Book Type DVD+R
    Media Type DVD+R
    Default DVD+R book type DVD-ROM
    Media Id Code Speed 4.0x 5540KBps
    Available Write Descriptor CLV 0.0x 2KBps
    Linear Density Blank Disc
    Track Density Un
    Number of Layers 1
    01 02 00 00 A1 0F 02 00 00 03 00 00 00 26 05 3F .............&.?
    00 00 00 00 00 00 01 52 49 43 4F 48 4A 50 4E 52 .......RICOHJPNR
    30 31 02 38 23 54 37 09 00 3C 67 00 AC 62 16 18 01.8#T7..<g..b..
    0B 0B 0A 0B 01 19 1B 0B 0B 0E 0F 01 00 00 00 00 ................
    You must be a +R user then. Not sure what to say. Bad media, bad program, bad burner, dirty burners, lots of options here.
  8. Originally Posted by lordsmurf
    Add one more option: old firmware that can't deal with a new 4x media.
    BTW tgm, what's your burner, what's its firmware?
  9. Philips DVD+RW SDVD6004
    Serial # AB12
    FIrmware Revision 1.03
  10. This is a slim DVD+R/W writer that comes with DELL notebooks right?
    These kinda problems you're having can usually be solved with
    - updating the firmware (ask Dell if they have one)
    or
    - updating or changing the burning software (RecordNow Max , Nero)
    I found the RicohJPN medias reliable but it can be a bad batch.
  11. https://www.videohelp.com/forum/viewtopic.php?t=172521
    "Using CopyToDVD to burn to DVD-R(W) Each time a choose 'Write DVD' from the drop down menu - it always rejects the media, at least once sometimes twice. This occurs wether the media is in the drive prior to launching CopyToDVD, or is inserted after. I always wait until the drive has initialised and stopped accessing the media."
